Originally Posted by
WHTPOLOGTI
ive fitted ford mondeo drop links and new bushes recently and still the clunk and knocking/rubbing felt through steering is still there.
Did you fit the drop links with the car still on the ground? If you jack the car up the sway bar will not sit correctly (as it won't have weight on it) and you'll still get knocks. If you have done this loosen both drop links while the car is on the ground, then re-tighten once both sides are undone and loose. Make sure you loosen both sides before you tighten either side.
Also, I found you do need to put the nuts on quite tight to get them to not loosen and shift over time. You may need to loosen the nuts on the top of both drop links (while the car is the on the ground) then re-tighten them both very firmly.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
