Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 134
Thread: Clicht Build Thread
  1. #101
    Jan 2012
    Bentleigh East, Melbourne, Vic
    I installed my THS Seat Cooler today
    What a job ! took me quite a few hours !
    And guess what....
    when I boost past 10psi, I get a whistleing noise coming from the turbo / cooler....I assume one of the pipe are not tight enough...arrrgh, now I need to start tightening pipes again -- unless anyone has any other suggestions.
    Anyway, here are the pic's:
    cooler comparison:
    Before install:
    Installed:
    Installed with pipes being put on:
    Polo 9n3 GTI
  2. #102
    Looks pretty swish mate!
    Done a great job on it so far, keep it up.
  3. #103
    Quote Originally Posted by clicht View Post
    And guess what....
    Top job Clint, do you have a boost gauge. Is it down on boost when whistling?
    Defo check all the boost pipes again.
  4. #104
    Jan 2009
    blankedy
    Clicht Build Thread
    Yep, did my Seat core today, same issue! Boosting moderately feels fine, boost hard and I can hear it. Car feels fine on boost, not great. I wonder which connection it will be, hoping I don't have to pull the bumper off again.
  5. #105
    Jan 2012
    I know, it was quite a job.
    Put up pics.
    Polo 9n3 GTI
  6. #106
    Jan 2012
    Thanks Gav,
    I do have a boost gauge, and normally it will boost to 18 psi, now it only hits 14 psi, so back to the pipes.....
    Polo 9n3 GTI
  7. #107
    Jan 2012
    Got my tools together, was just about to get the bumper off again, and thought....Sh#t, not today...so just washed the car.....will look at the pipes perhaps next weekend
    Polo 9n3 GTI
  8. #108
    Aug 2007
    Good on you for having a go mate. yes tasky hey. Anyway whosh will most def be boost leak. this is where i probably won when doing VWindahouses one, before i refitted the bar cover i smoke tested it for itegrity, i guess hard for you guys without that sort of gear. i know it makes it hard to say whilst you have your front PU back on but its best you make sure the clamps are all new and proper tight.
    Im sure will get it, good work!
    Jmac
    Alba European
  9. #109
    Yep, those bastard T-bolts always have to tighten up muchhh more than you think... spray some hairspray inside them or on the pipe ends too
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  10. #110
    Jan 2012
    So I took my bumper off again, and found one slighly loose clamp...I retighted it, and then went through all the other clamps and made sure that they were tight.......very tight.
    After that I decided to finally fit my forge TIP; well what can I say but sh#t was a mission. There as screming and shouting and cuts and bruises, but finally after removing half the engine, I managed to fit it -- whooohooooom although wont be in a hurry to do this again. If anyone is thinking of doing this, drop me a PM, and I will give you a few tips
    Anyway, here of the photos of my cooler, with TIGHT clamps:
    and the TIP:
    Polo 9n3 GTI
