Hi all,
I started with my Polo Gti with a chip (APR). slowly slowly added dump pipe, intake, full exhaust and Front mount intercooler. Unfortunately, Ive added my boost gauge pretty much last..
Does changing intercooler or exhaust or even intake mods effect the boost..
My car had a strange episode the other day. I changed the air intake to a POD setup and it would only boost to maximum of 17.5psi (previously would go past 20psi)
But I decided to reset it and now it boost again to over 20psi..
At the moment give my car a hot and it will boost to over 20psi (my gauge only reads to 20psi) and then stabilised to about 18psi and past 5000rpm settle down to about 14psi...
But I dont know if this was the case prior to intercooler/dump etc..
But the other day, it just wouldnt boost more than 17.5psi.. didnt have that usual spike to over 20psi that it gets. doesnt matter what I did.. It felt slower through mid range as well.. dont know what it was..
I reset it by changing program on cruise control.. half an hour later all the boost was back and its flying??
Anyone know why it changed its temperment before the reset??
Sounds like the computer is taking some time adjusting to the different air flow.
Could it be that there is some restriction in the POD design you have? any turns or bends that have been added?
Its back to normal now but I reset it.. dont know why it stopped boosting as hard.. Maybe it had the flu?
Boosting now harder than ever..
Hey PP what POD do you have?
what apr map do you haqve vs1 or vs2? wish mine boosted to 20psi i get max 15-16 settles at 13 ;-( non apr but i might get apr if thats the boost you get!
Guy's and Gals, I have a question for you all. Took my car for a drive today after hooking up the boost signal tube, which by the way is fitted to the fuel reg. The cars boosting to 14psi? vacuum is -20 at idle. Is this standard boost on our cars? It's getting reflashed tommorow but just wanted to know what everyone else was boosting to when standard. The only mods I have at the moment is BMC air filter,Seat intake,and J N75 valve. Cant wait for tomorrow!!
Joe Chu
As I understand stock boost is around 8-9 psi, not sure what the spike goes to. After chipping goes to whatever the tune. Mine spikes at 19psi with an APR v2 tune, no other mods.
