Results 31 to 36 of 36
Thread: CC Stage 2 tune
  1. #31
    Nov 2012
    WA
    I've got stock suspension cept for bushes. Hard to break traction in second with good tyres. With average tyres could get 3rd going.
    08 9n3 Polo GTI
    Mods: heaps
  2. #32
    Jan 2014
    Clontarf, Queensland
    I am sure you can use less fuel than that mate!
    I have some Superpro bushes on the shelf if you fancy going that road. The ones can be set to anti-lift, the same as I have in mine.
    Haha probably Gav - I'm using your 5th gear style
    Would be happy with the superpro bushes - will give you a buzz.
    Mods >1
  3. #33
    Jan 2014
    Good news. I find the power to be quite peaky (esp in 1st). How much timing do you have dialed in? From memory I have around 8 deg.
    I have no idea how you've been managing with the extra power, I have coilies, front and rear sways, front brace and semi-slicks and can break traction in second if the surface isn't great. Most of our power mods are the same
    I think from memory I have about 7.25 for timing (Gav may remember better than I do). I still have the Conti's on it which have good tread but are cracking a bit on the sidewalls. You do have to really hang on to the steering wheel when the boost comes on but now that I'm used to it it's not too bad. I also have the Powerflex track dogbone bush which seems to keep things together really well. The vibration from the dogbone has settled down a bit, but is still very noticeable with the a/c on. I just turn the stereo up
    Mods >1
  4. #34
    We didn't get to 11 that's for sure. I remember leaving it a bit in reserve for the hot days.
    I can turn up the idle to stop the buzz from the AC/dogbone.
  5. #35
    Jan 2009
    blankedy
    Idle is much better just over 1k, I'll be upping mine when I get around to it (and a clean).
  6. #36
    Jan 2014
    Good to know - mine is about 750-800.
    Will organise a time to catch up Gav.
    Mods >1
