yep no worries. get in contact when you want to do it and we'll have a chat.
Nissan Silvia S13-S15/ 180SX/ 200SX Camber Caster Front Strut Mount | SC44020S
I have used Greg Nolan's strut tops on cars for decades, even helps design a couple. They allow adj in all directions and have replaceable (common) spherical bearings which it will need once a year if its daily driver, less often for a "Sunday" car. In race car applications I apply stick on sand paper to one side of the sliding surface which prevents slipping, otherwise tighten regularly. I mark the strut tops for the various camber settings, that way I can adjust them quickly without breaking out the camber gauge and trying to find a flat surface between runs/races/sessions.
Gary
Resident grumpy old fart
Do the ground control plates for the Mk4 Golf bolts straight in or do they need moding?
I installed Silvia camber plates on my 9N, rotated for extra caster. The holes on the strut tops need drilling, because the PCD on the Silvia plates are 1 or 2 mm larger. Otherwise, i machined some pieces to allow me to use a bearing and to adapt them to my AP coilovers, because i didn't want to experience coil bind when turning the wheel.
With TT ball joints, subframe excentric bushes and the camber plates rotated, the caster is about 6.5 degrees and now the camber is set at -2.8 but can be maxed at -3.5 with all this modes.
89437982-766045103923118-4249096993739112448-n — ImgBB
88444849-150390009458386-8640575155522764800-n — ImgBB
89365956-1124897531177621-2898301376528384000-n — ImgBB
89498462-139516260753303-3479023406404337664-n — ImgBB
yep thats about where mine ended up too mate but with slightly different strut tops to you. good stuff
