Results 11 to 20 of 27
Thread: Caster Discussion
    Jan 2009
    blankedy
    Quote Originally Posted by kaanage View Post
    Here is a description of this product.
    Wrong thread? That one is about Viezu...
    Jan 2009
    blankedy
    The road feel is likely caused by the bushes being Poly. I went from the whiteline ones to Seat for this reason.
    Eddy has the K-mac adjustable strut tops. They look good but not cheap and likely pass more noise / vibration than stock.
    The nice thing about the K-Mac's is they can provide castor and camber adjustment.
    I've not seen any other products for altering the front end geometry (well, suspension height alters the camber).
    It may be after I get my toe fixed (wheel alignment) that I forget about this one.
    Oct 2010
    Melbourne, VIC
    Whoops - cut and pasted wrong link. Now fixed (check it out - it's quite interesting)
    For road use, I agree - I don't see why you need more than proper toe.
    For track, some negative camber at the front would be the biggest gain IMO.
    Jan 2008
    Negative camber can make quite a difference, had it on my previous car and I have also had a drive of a couple of other cars with neg camber. The turn in is great, so much grip! There are some down sides to it too. Tyre wear on the inside being one. The other which I experienced, was the front would lose traction when braking hard in the wet. And not because I was locking up the brakes. The reduced contact area with the road and the road being wet made it more slippery than it would have been otherwise. Though I should point out that the camber I had was a bit aggressive ( -2.5 deg or -3 deg , I cant remember now).
    The Polo being a different car with different tyres and all the other variables may not respond the same. Also with less camber dialled in you probably won’t wear the tyres on the inside as much and you may not have traction issues in the wet.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    WRONG, me don't have K-Macs #*+#.
    These are custom by Extreme Motorsports brissy ( they are quality with the highest standard pillow ball) , gained a small amount of caster, but love the camber -2 degrees for the road & over -3 for the track.
    http://
    Hooroo.
    Sep 2006
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    They are custom, can they make another set, guessing they are not cheap, also with the APR K04 tune, is it agressive, what does the boost peak at (psi)
    Sep 2006
    Tweed Heads
    Quote Originally Posted by vwthunder View Post
    Hoyhoy.
    When I say custom, I mean very custom, a lot of my own hours fiddling.
    Boost spike is up there.
    Hooroo.
    Jan 2009
    blankedy
    Sorry mate, thanks for clarifying. Not sure why I thought you had K-Mac's. Did you look at the K-Mac's?
    Anyways, it would be great to get your feedback and some more input from you Eddy as you are the only one who has done this on the Polo / Cupra that I've seen.
    Has it added any noise? Would you happen to know if the K-Mac's would work?
    Sep 2006
    Van has the Kmac's on his polo, maybe you can PM him, I have spoken to him about this and he says that there was not really a noticable difference, then again, his car is quite loud and he is running 18's
    With the Kmac's there is cutting involved too
    Sep 2006
    Have a look here
    Im not sure if the Mk4 gti have the same strut tops as a Polo
    VWVortex.com - MkIV Camber plate list
    Everyone says the Ground Control are the way to go
