Results 1 to 10 of 15
Thread: Car sounds like vacuum cleaner on start
    Mar 2007
    Gold Coast
    Hi folks.
    My car has taken to sounding like a vacuum cleaner for about a minute when I start it from cold. Any idea what this might be? I popped the bonnet this morning to try and listen to where it was from but couldn't really pinpoint it. It sounds like a motor/ fan spinning at high RPM which winds down after about a minute. Also, the idle appeared to drop (to normal speed from slightly high) when it stopped.
    Cheers,
    -Phil,
    Jan 2009
    blankedy
    Its not just the choke? My car sounds rough, idles around 1000 rpm for 30 sec - 1min before settling down.
    The combustion is much richer, which helps protect the engine from damage when cold.
    Mar 2007
    Gold Coast
    hmm, not sure. It's a distinct fan/ motor kind of sound, and fairly loud. High pitched though, not like the cooling fan.
    Jun 2009
    Quote Originally Posted by philthy View Post
    sounds like an auxiliary air pump problem.
    Mar 2007
    Gold Coast
    Quote Originally Posted by mattyf View Post
    Hmmm. What does that do?
    Maybe I have a split pipe or something.
    Jun 2009
    something to do with making cleaner exhaust emissions on startup.
    the bearings in the electric motor could be u/s.
    you could check for leaks by feeling the small hose that runs from the airbox to the auxiliary air pump when its running
    Mar 2007
    Gold Coast
    Will have a look at the hose. I googled auxilliary air pump and what came up did look familiar. I think it hangs off a bracket on the front of the motor and that was where the noise was coming from.
    Thanks mate.
    Nov 2008
    Killara Sydney
    Thanks mate.
    Air pump pumps air into exhaust on cold start up to heat the catylyst up for cleaner emissions and get the cat up to temp quicker. The pump filter might be dislodge causing the noise?
    Joe Chu
    Mar 2007
    Gold Coast
    Quote Originally Posted by Joe Chu View Post
    Hi Joe. Where is the pump filter located? I felt the pipes coming from the pump yesterday and had another listen. Couldn't feel any leaks and the noise definately seems to be coming from the pump.
    Will take it to the mechanic when I get a chance.
    Jan 2009
    WEst Sydney
    Does the noice stop after 30 seconds or so... if so its normal. forget about it..
    Pull the hose off the airbox, start the car cold and you will feel the vaccumm, after 30 seconds stops.
    Maybe you hose has come lose somewhere for the additional noise..
    I thought the same thing, went to VW about it and they said forget about it, normal
