Its not just the choke? My car sounds rough, idles around 1000 rpm for 30 sec - 1min before settling down.
The combustion is much richer, which helps protect the engine from damage when cold.
Hi folks.
My car has taken to sounding like a vacuum cleaner for about a minute when I start it from cold. Any idea what this might be? I popped the bonnet this morning to try and listen to where it was from but couldn't really pinpoint it. It sounds like a motor/ fan spinning at high RPM which winds down after about a minute. Also, the idle appeared to drop (to normal speed from slightly high) when it stopped.
Cheers,
-Phil,
hmm, not sure. It's a distinct fan/ motor kind of sound, and fairly loud. High pitched though, not like the cooling fan.
Does the noice stop after 30 seconds or so... if so its normal. forget about it..
Pull the hose off the airbox, start the car cold and you will feel the vaccumm, after 30 seconds stops.
Maybe you hose has come lose somewhere for the additional noise..
I thought the same thing, went to VW about it and they said forget about it, normal
