The older turbo nissans had a similar fault (silvia's, skylines) and it was the air flow meter either being faulty or faulty wiring to it. Could be something to bring up with them (if they haven't checked it already). Apart from that![]()
Finally got my car back from agents, my joy lasted one day, then same problem again. I've had my car 3 days in the last month.
Since new it has had a fault - EPC & ESP light comes on, engine kills power. Usually happens when I overtake changing from 4th - 5th gear. A bit dangerous, seeing as the GTi is made for overtaking.
VW agents have no clue what to do, they have replaced pedal assembly, throttle control, both cam sensors and checked the wiring.
Been going on for 1year already, problem comes up at leats once a month, I've had enough.
Negotiated a deal for a new GTi, hopefully take delivery on Monday![]()
GTi-SA
Yeah I hope your not paying a cent for the new one. Hope it works out![]()
aus liebe zum automobil
You would think a misbehaving ESP/TC would be due to some part of the sensors (ABS) rather than the engine ancillaries.
it is almost impossible for a dealer to replace your car with a new car...
Unfortunately not so lucky, after much hassle I managed to get them to take back old one and settle HP with bank. The new one I have to purchase outright with a decent discount.
Heard via the grape vine that the fault is due to me "spinning the wheels". Apparently this causes all sorts of major probs
Original conti,s gave me 46000km!!!
GTi-SA
I'm sorry but that to me wouldn't be acceptable, if there is a technical fault within warranty they either fix it or replace the car, otherwise what's the point of buying a new car with warranty. You might not be blessed with dealers where you are, but if you have the chance I'd be getting a different opinion or be going to VW directly.
Just my thoughts, you buy a car for x price, problems that stop your car from working daily should be fixed as part of warranty. You now have to pay for a second car, because VW can't fix the problem? That's not right.
