The "case" is really just the lid - the side walls clip off leaving a fairly flat lower platform, then reducing battery dimension by 2/3rds gives enough room (Odesey battery). You can carefully rotate the lid & relocate some cables. The 05' has a second plastic cover which covers the electrical terminals.
Also your airpump feeds into the stock airbox, so you must place a breather filter in to protect the pump & make sure it gets clean air.
