I think you will find that they are 81mm standard.
BJX out of the polo 9n. Need new pistons with 8.5:1 compression. may consider either boring it out to 82mm or bore and sleeve the 81.5mm. im just guessing the sizes though :/
Thanks mate.
Resident grumpy old fart
