Results 21 to 30 of 36
Thread: Cambelt should be done at 7 years/105k. So what else to do at the same time???
  1. #21
    Aug 2013
    A good set of torx bits will be helpful. The Crank Pulley will require a 5mm hex head (allen key) to remove so you can get access to the covers behind.
    Aside from this, all bolts behind the timing covers are 10mm which includes tensioner and water pump. The idler pulley is either 12 or 14mm bolt.
    The only thing I can see being an issue to someone attempting to change theirs for the first time would be keeping the pulleys in line under tension as the cam gear has a tendency to move once the tensioner is putting some backward force on the belt...
  2. #22
    Good comments guys, so to really sort this belt issue is there a good DIY thread or Utube on this subject out there? Cheers Al
  3. #23
    Quote Originally Posted by Polo GTEye N9 View Post
    VWVortex.com - Ultimate Timing Belt DIY!
  4. #24
    nsw
    is it imperative to go for a genuine VW kit or is it much of a muchness between that and the aftermarket ones?
  5. #25
    Quote Originally Posted by sambb View Post
    What aftermarket ones? From ECSTuning or the likes of Imparts?
  6. #26
    nsw
    no I'm not after high performance belt kits. I just figured there'd be genuine factory VW ones and non-genuine original replacements from supercheap/autobarn etc. is there anything to separate those ones?
    thx
  7. #27
    thx
    ECSTuning doesn't mean performance. There's a Gates racing belt like I have on my Polo. Which is the same money as full retail on the aftermarket belts.
    There's lots of reproduction/non-gen water pumps, tensioners, rollers out there but none are better or worse in my opinion. The quality is consistent as far as I am concern.
    Continental, Gates, Optibelt, Dayco all do kits. I could get a full kit for $+-375 from Imparts for you. Don't go mad looking for metal impeller water pumps. The modern plastic ones will outlast the belt all day long.
  8. #28
    Jan 2009
    blankedy
    If you end up organising a few, I'd be in. Still only 52k Km's, but it's an 06, so won't be holding out for the max mileage.
  9. #29
    Aug 2013
    *Shameless plug* I have a standard 06a motor timing kit which is surplus to my needs (I have gone with a Gates manual system).
    Includes steel impeller water pump, hydraulic tensioner, and new pulley.
    But as Gav was saying, anything between $100 - $350 is where it's at for costs on timing kits.
  10. #30
    Quote Originally Posted by quattro5v View Post
    Good deal, add a link Mike!
    Do note that the belt roller on the BJX has a different part number to the rest of the 06A motors, no idea why.
