There's a small hole down the left side, down behind the ecu, in front of the passenger footwell.
Does anyone have any suggestions on the best route for cables to carry the signals from boost and/or EGT gauges?
Can it be done without drilling holes in the firewall?
Resident grumpy old fart
Cheap, Fast, Reliable. Choose two.
What EGT gauge do you have or are looking at buying.
I am looking for a EGT and AFR gauge or a combo gauge to reduce clutter.
