I ended up getting mine from Highway Volkswagen for $88... I rang around all the wreckers and had no luck plus on-line searching turned up nothing.
I am not sure if you can re-build the resistor as it is covered in a ceramic-like substance, then the resisters are housed in a plastic casing (I pulled my broken one apart
) Breaking the ceramic coating will have an effect on the performance
'06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
- You may not post replies
- You may not edit your posts
Forum Rules
