Results 1 to 10 of 12
Thread: Buzzing Sound 3500-4000rpm
    Kuala Lumpur
    Hi Guys,
    Lately I've been hearing buzzing sound at 3.5-4k rpm on WOT, not loud but noticeable enough. The car has been chipped but stock DV and stock TIP, 39k kms and CEL didn't pops up.
    Is it possible the wastegate/spooling noise getting louder or boost leaks? I don't think it's loose turbo bolts coz I didn't get any vibration at cold startup and didn't notice any significant drops in performance either. Puzzled
    Jun 2009
    PJ/Selangor, Malaysia
    maybe it's just a loose panel. where does it sound like it's coming from?
    is it loud? is there something else that sounds similar to it because trying to diagnose and understand what buzzing sound means over the internet is difficult.
    no power loss?
    Kuala Lumpur
    Quote Originally Posted by jesum View Post
    no power loss?
    Hi,
    I don't think it's loose body panel sounds coming from the engine bay. Not loud but noticeable, no noticeable power loss....
    Jun 2009
    1. could it be something is loose in the engine? try removing the engine cover.
    2. ask someone to rev the car at 3.5k -4k rpm and hold the rpm while u listen to the engine from the outside with the bonnet open.
    3. did someone leave a screw or some tools inside?
    4. does it buzz when you go over rough surfaces?
    since you did have the car's front bushes changed recently, check all the screws on the subframe (k frame, arm, etc) to see if they are tight. the source of a sound can be very deceiving at times....
    Jan 2009
    Bucharest, Romania
    Don't exactly know how your "buzz" sounds - but check two things :
    - check if you hear the buzz - with the windows opened / while opening them - I hear sometimes some kind of buzz when accelerating with the windows closed, but disapears when I open them
    - check the cap of the windshield washer bottle - had the cap not closed properly and it made similar sound to what you are describing.
    Kuala Lumpur
    Hi,
    Thanks for your insight. Managed to find the culprits. One of it is my downpipe's flex flange section showing signs of premature aging while the other is the stock DV.
    Oct 2006
    What year model is your Pog?
    Revotechnik stage 1 flash, BC Sports coilovers, Lenso Type M's, APR R1 diverter valve
    Kuala Lumpur
    2008 mate
    Jan 2009
    blankedy
    Forge diverter may help you retain more boost (thus more power)
    Nov 2008
    APR R1 DV is good as well ... you can pick them up cheap from the states
