welcome. Long overdue to come say g'day.
I'm going to sound like an a55hole without intending to do so, but if you don't notice the improvement in handling between stock and bilstein "I’m probably not a good enough driver to be able to tell the difference", is adding more power wise?? You'll have to be more careful with throttle application due to the increased power. You've got the right set-up to handle the power (see my signature)
Stage II isn't just a downpipe. To reach stage II is typically air intake, diverter valve, turbo intake pipe, dump pipe, front mount and the associated tune. Corey may have done some of these mods already, he was quite active on here so wouldn't be surprised. I've just added the air intake on the weekend, and that's a nice little improvement over standard intake.
