Hope that's clear enough.
Just to give it a bit more perspective, the maximum difference between Jason and your requested boost is .6 psi.
Legend! Cheers mate![]()
Wow, way to run a comprehensive Dyno and data collection guys, world class stuff. A template for future dyno comparisons!!
What was with the MK4 GTI Stg3 making a low 153.554kw, but a huge torque number 396.328
MODS- TOO MANY
Maybe that's a reflection of the small port 1.8t v's the large port?
Lito, has a Frankenturbo with CC. AFR (Air fuel ratio) was dangerously low. Tried 3 runs each aborted when AFR went to 1.2 ... 1.3. Finally decided to risk it and do a run that was also aborted at 4500rmin. Guy and James was not willing to have the engine self-destruct in their workshop .....
So it made 153kw at 4500rmin with no idea as to what it would make if allowed to run out to 6500rmin. It was a clear indication of (a lot) more tuning needed ........ Good torque though.
Lito can post the graphs up if he wishes. Extra graphs showing the AFR was done for him.
Also now the reason I will not go Frankenturbo ....![]()
For those that want to know what the AFR is about see this graph:
All t
All the data above are showing Lambda figures ....
