Item Description ECU APR Stg1 V2 Intake PD160 Filter Stock MAF Stock Diverter Diverter Spring N/A TIP Stock Turbo Stock K03S Exhaust Manifold Stock Downpipe Miltek Turbo Back 2.5 Cat Miltek Turbo Back 2.5 Rear silencer Miltek Turbo Back 2.5 Intake Manifold Stock Intake Manifold Gasket Stock Intercooler Stock Intercooler hose Stock Clutch Stock Flywheel Stock Crank Pulley Stock Fuel Pressure Regulator Stock Fuel Pump Stock SAI Pump Stock N249 Valve Deleted N75 Valve Stock N112 Valve Stock Spark Plugs NGK BKR7EKT Ignition Coils 2.0 TSI
Key Data Run 1
RPM Boost Reqd mbar Boost Actual mbar RPM Intake Temps AFR 1760 1670 1380 1760 33 0.852 1960 1750 1410 2120 33 0.844 2320 1980 1710 2440 33 0.86 2640 2090 2110 2760 33 0.86 3000 2120 2230 3080 35 0.86 3320 2120 2140 3400 37 0.867 3640 2130 2130 3720 40 0.86 3960 2150 2110 4080 45 0.86 4320 2100 2120 4400 50 0.844 4640 2080 2050 4720 54 0.867 4960 2020 2020 5040 58 0.86 5280 1950 1980 5360 63 0.86 5600 1890 1910 5720 67 0.844 5920 1810 1850 6040 71 0.86 6280 1730 1830 6360 75 0.844 6480 1690 1760 6480 78 0.86
