dry/unlubricated caliper slides will cause irregular wear of pad's and rotor's ensure when you put the new pad's and rotors on you lubricate them with special hih melting point caliper slide grease
GSL RallySport 1300 884 836
Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
QFM Performance Pads
Another Q,
I've been told by a mechanic that Euro rotors shouldn't be machined. Anyone able to comment on that, as I can't see why not.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
Just for the record it was me that suggested that the rotors not be machined and seeing as im on display ill happily comment. If you have a lip or bevel im sure you will be close to the minimum thickness. There is 3mm between new and old, if your rotors are already showing signs of lipping then you will take out the hardening of the rotor and /or get near the minimum, in which case if you do the new pads will out do the machined rotor, im happy to take critisism here too, i wouldnt machine them and on the same token i wouldnt just replace them willy nilly either.
Jmac
Alba European
See the PM Jim, I posted that up this morning prior to calling you in the afternoon for the quote and clarification.
Thanks for the clarification on the phone, much appreciated mate!
Edit: Your inbox is full so can't reply to your PM mate, can you let me know when you've cleared it up.
