Results 1 to 10 of 15
Thread: Brake rotor wear - Question
    Aug 2009
    Hey All,
    I had the good 'ol brake pad wear light come on the other day and had a check of the pads/disks. The pads still had a bit left in them, but for safety sake I decided to order a new set.
    The rear rotors are evenly worn down, and have minimal wear across the entire rotor. So I decided to keep them and I will just get them machined prior to fitting the new pads.
    However, the front rotors, particularly the front left is very unevenly worn.
    On one edge of the disk it's still a good ~1cm thick, where the opposite side of the face of the disk is ~4mm thick. I'm completely baffled how a disk wears at an angle across the face of the disk. I have no brake fade, no vibrations under heavy braking, and no squealing from the front disks.
    Anyone got any idea what might of caused this sort of wear? I've seen uneven pad wear cause other patterns on the rotor face, but never this type of wear.
    Oh, and side note. Can anyone suggest a quality brake fluid for the Polos? It's my understanding it's a bad idea to mix brands of brake fluid, but I have no idea what the Polo's run stock.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Jan 2009
    blankedy
    ??? That sounds pretty scary.
    My understanding of uneven wear is that it would not be visible. the actual wear of the disc is only a few mm's, so having one area of a disk heavily worn is very strange... When I had my discs machined, you could not see the uneven wear (was originally told by a few people warped, but just uneven wear likely to do with ABS braking at the track).
    Any chance of a photo?
    Martini brake fluid is a preferred choice, I got mine from ebay seller in Tassie (need 2 bottles) or one of the Mechanics on here can probably help you out.
    The Pad indicator will come up well before you need to change the pads (thats kind of the point of the indicator), I'd be much more concerned about your rotors than pads with 1/3 bite left...
    Aug 2009
    <snip>
    Yeah, I'll organize a photo when I can to give an example.
    Cheers on the brake fluid recommendation.
    But yeah, front pads still have ~5mm, where the rears have ~3mm. Still enough to not panic yet... but the state of the rotor is quite worrying.
    I can't imagine what might have warped the rotor or caused this wear. While I am a mountain run junkie, I always give them a good warm-up and cool-down before and after, and even with my punishment they've never given me any loss of pedal feel or braking ability during any of those runs.
    Jan 2009
    blankedy
    I have a set sitting here doing nothing, but they are damn heavy, so freight would make getting them to you expensive.
    Aug 2009
    Cheers for the offer, but I've already ordered a set of front rotors so I'll be right to get all this fixed up nice and quickly.
    Jan 2009
    how many km's you done?
    Another post yesterday had a bloke wearing out the rotors in 45kms. I'd have thought that was a bit premature unless it's driven hard regularly. Alfa romeo's are a 60,000km life for pads and discs, wouldn't have thought ours would be less.
    Aug 2009
    Quote Originally Posted by seangti View Post
    I've just hit 50k on the clock. I've had the car for 13k of that, and while the previous owner was an older lady I've definitely given the brakes a workout as I like my mountain driving.
    Quote Originally Posted by break View Post
    If you're just after a standard street fluid, then any $7 bottle of Dot 4 from your local servo will be fine, regardless of brand. Dot 3 and 4 are formulation standards, not performance standards, so all Dot 4 fluid is virtually identical.
    If you're after a performance fluid the stuff that we use and recommend is the TRW GP600 Dot 4 Racing Brake Fluid. Good for 312 degrees (or exactly the same as Motul RBF600) and made by the same manufacturer that makes the majority of the braking components for the Audi/VW group (TRW). $65 for a 1L bottle.
    GSL RallySport 1300 884 836
    Sick of paying too much for performance brake pads? Want high performance with low rotor wear?
    QFM Performance Pads
    Jan 2008
    Mallacoota, Vic.
    Uneven disc wear
    I've seen that sort of uneven wear on my son's Bora V6. Turned out to be a loose axle nut (LHS front) allowing the outer edge of the disc to contact the calipers, probably just on right turns. So worth checking the axle nut torque.
    Brian
    2007 Trakkadu
    Jan 2009
    rotor wear
    I have found that my brake pads/rotors have not lasted particularly long (a little less than break's).
    This was the reason for my decision to upgrade to 312mm s3/tt combo, I figured that while I was replacing I should go for something bigger.
    Apparently good brake fluid makes a big difference.
    Personally I think the brakes and handling are the biggest limitations of the pog - even with stock power
