Originally Posted by
simon k
I spent a couple of hours tonight with my mate using his pressure bleeder and VCDS, the pedal is a bit better than it was but still squishy. We put at least 4l of fluid through it and I'm sure there is no air left in the system.
I've tried a few hard stops on gravel, wet road, different speeds etc. and the pedal is OK for one application after that but it goes squishy again
I rang a couple of VW wreckers to see if they knew of an alternative bigger bore MC but they had no clue (and didn't really want to help). Can anyone recommend someone with a bit of imagination who'd know what might be interchangeable?
One stop then squishy, that sounds like pad material, what are you using?
Gary
