Results 1 to 5 of 5
Thread: Brake pad wears warning
    Jun 2008
    Hi all,
    If i change a set of aftermarket brake pads that doesnt come with the sensor, will i get the warning light on the dash?
    Thanks!
    Jun 2008
    The sensor is not actually part of the pad. You sort of attach it back after you've put the new pads on.
    Jun 2008
    I am going to fit an aftermarket pads on, not sure it can be fit back to the pads or not...
    Aug 2007
    Quote Originally Posted by Roodosutaa View Post
    EH???? The sensor is on the pad mate. If you buy aftermarket pads some come with sensor, Remsa for one do. Others that dont you need to drill a hole in the friction material and fit a new sensor. If you dont want the hassle of that bridge the contact
    Jmac
    Alba European
    Jan 2009
    blankedy
    Pretty easy to connect a wire between the pos / neg terminals to create a circuit. Its just a relay style connection (open or closed)
