Have you tried putting grease in between the outside of the pad and the caliper? You obviously don't want any on the pad or rotor surface.
As the title says, I've got a rattle coming from both front brake calipers and on further examination I've found that the lower caliper slide pins seem to have excessive play resulting in the caliper rattling around over the slightest of cracks in the road. I can physically make the caliper rattle when parked by pulling the caliper towards the front of the car and back. Just lightly resting my foot on the brake when driving causes the noise disappear.
Perhaps the slide pins are worn, or maybe the caliper/carrier is worn?
I've tried the VW dealer to try order some new slide pins but unfortunately you have to buy a whole new carrier to get the pins which is quite expensive..
If anybody knows of some original Polo gti brake carrier/calipers or has some left over after an upgrade, I would be very pleased to finally get this rattle sorted!
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
Landmark Spares are wrecking a 9n3 Gti at the moment - not sure what they have left, but might be worth hitting them up
30 Fairfield Street,
Fairfield East, NSW 2165
Phone: (02) 9632 5225
i've got the same problem (I think) ever since I replaced the front discs and pads on mine with EBC - sounds like I have a rattlesnake in the car under braking - super annoying, but unsure on what I can do to fix it.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Not yet. I think its more the caliper hitting the carrier causing the rattle
My rotors are in need of replacement soon but i wouldn't have thought that could cause it. I'll be replacing them this weekend with any luck, maybe that's my noise
Thanks, I'll check them out!
Heres a video taken from the inside front right wheel.
2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
Thanks Louis19!
I sent you a pm
Special thanks to Louis19 for his old brake carriers and slide pins !
The rattle is now gone and the car feels much more refined
Below is a picture of the slide pins from both my car and louis'
Mine were missing the rubber bushings on the end causing the metal on metal rattle
