Have you pressed your unlock button twice in quick succession?
Hi all.
would like some help as to my boot not opening from the handle.
thanks in advance
Yeah, if the passenger door has not been unlocked with key-fob, it stays locked.
Can you use your key to open the boot?
2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
Have tried both the suggested tips also
It's an intermittent fault as well
Sometimes it would open via the handle and sometimes won't
Hi I also have this problem.
After opening it from the inside manually normally fixes this for a few days then happens again.
ipoop - yeah same here.
bit of an annoyance.
still hoping someone on here who can help rectify this issue or point me in the right direction
i had that issue b4, I found that it just a loosen screw which hold the mechanic to operate the lock.
Can you guys hear any sound when you CANNOT open the boot?
Might get you some idea when you see the pic. (sorry written in chinese this time LOL)
Welcome To My PUG GTI Station: DIY
Any chance you can translate that Kelvin? Otherwise I'll get my mum to read it and post up the comments
BTW Where do you drive your Pog in HK? The only good road I know is the Peak and it's never empty except really late at night!
Resident grumpy old fart
