Results 1 to 9 of 9
Thread: Boot not opening polo gti 06
    Oct 2010
    Dulwich Hill, NSW
    Hi all.
    would like some help as to my boot not opening from the handle.
    thanks in advance
    Peregian Beach
    Have you pressed your unlock button twice in quick succession?
    Jan 2009
    blankedy
    Yeah, if the passenger door has not been unlocked with key-fob, it stays locked.
    Can you use your key to open the boot?
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    Oct 2010
    Dulwich Hill, NSW
    Have tried both the suggested tips also
    It's an intermittent fault as well
    Sometimes it would open via the handle and sometimes won't
    Apr 2012
    NSW
    Hi I also have this problem.
    After opening it from the inside manually normally fixes this for a few days then happens again.
    Oct 2010
    Dulwich Hill, NSW
    ipoop - yeah same here.
    bit of an annoyance.
    still hoping someone on here who can help rectify this issue or point me in the right direction
    i had that issue b4, I found that it just a loosen screw which hold the mechanic to operate the lock.
    Can you guys hear any sound when you CANNOT open the boot?
    Might get you some idea when you see the pic. (sorry written in chinese this time LOL)
    Welcome To My PUG GTI Station: DIY
    Oct 2010
    Melbourne, VIC
    Any chance you can translate that Kelvin? Otherwise I'll get my mum to read it and post up the comments
    BTW Where do you drive your Pog in HK? The only good road I know is the Peak and it's never empty except really late at night!
    Resident grumpy old fart
