Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: boost vs rpm
    Jan 2009
    blankedy
    Ah! Name your lines! Also, if you can, remove 1000 mbar from the results so idle is 0, not 1000 (easier to read)
    Looking good, the best graphs are from the 1 block, requested and actual in 3rd gear. Looks solid.
    I wouldn't expect much more boost, but adding the timing and keeping an eye on the timing pull is where it gets fun. adding 1.5 deg of timing on my toy is noticable, so if you can get 4 or 6 in safely, should get some mean torque.
    Jan 2012
    Bentleigh East, Melbourne, Vic
    I will redo a beter graph .
    I have also got the detailed logs that I sent Gavin...let me know if you would like a copy ?
    BTW: look at my build thread...Ive started on the timimg hahaah
    Polo 9n3 GTI
