Results 1 to 10 of 12
Thread: boost vs rpm
    You need to run logs in 3rd gear, you'll never see proper boost in second gear.
    The intercooler may have some bearing on things.
    Jan 2012
    Bentleigh East, Melbourne, Vic
    Just put the ecu in, and ran the same test on vagcom (115) with custom code. I now need to work with Gavin to fix up a bit, however at first glance, it is not as smooth, but it does boost higher.
    At approx 4200 rpm, the requested boost suddently drops off:
    rev's reqsted actual
    4160 2290 2240
    4360 1750 2220 **this is where the boost suddenly drops
    4560 1880 1920
    4880 2030 1910 **this is where the boost increases again
    Peak boost was at about 3700 with 2310mbar ( approx 19 psi). (VCDS)
    Polo 9n3 GTI
    Quote Originally Posted by clicht View Post
    4160 2290 2240
    4560 1880 1920
    Can you email me that log mate and confirm you took it in 3rd gear.
    Jan 2012
    Did it in 2nd gear again, just to do a like for like test.
    I will do it in 3rd gear tomorrow; but I like it seems to pull off the mark quicker.
    I will however mail the logs to you.
    BTW: this is customer service, a voicemail on my mobile at 22:30 from Gav (just a bit embarassed to phone back at 23:50)
    Polo 9n3 GTI
    I said I was up until Midnight.
    You need to do the 3rd gear pulls, 2nd will never give you a good look at what's going on, it's over too quick. The sampling rate is too low to capture much info.
    Jan 2012
    In third gear...looks much beter
    peak boost at 3640 rpm with 2400 mbar (20.1 psi) woooohooooo ; and still need to tweak it !
    Polo 9n3 GTI
    Jan 2009
    blankedy
    Ah! Name your lines! Also, if you can, remove 1000 mbar from the results so idle is 0, not 1000 (easier to read)
    Looking good, the best graphs are from the 1 block, requested and actual in 3rd gear. Looks solid.
    I wouldn't expect much more boost, but adding the timing and keeping an eye on the timing pull is where it gets fun. adding 1.5 deg of timing on my toy is noticable, so if you can get 4 or 6 in safely, should get some mean torque.
    Jan 2009
    Well here's mine against requested boost
    and actual boost in psi against revs.
    Might help to compare. I'm running superchips tune. Max actual boost 17psi. I'd have to relearn the maths to recalculate, but max requested mbar is 2200 at 3700 rpm.
    Daily: 2010 VW Jetta Highline
