Originally Posted by
noone
The wastegate is controlled from the N75. I would be surprised if you were able to generate that much boost.
I dont know the device youre using, so it could be something to do with that, dodgy sensor (although if it was you'd probably end up in limp pretty quick).
Assuming its using the MAP sensor, it wont show below ambient pressure, so the info above would indicate 30 units. As it does not say PSI, might want to confirm that. The K03s would struggle to produce more than 22 psi near the redline.
Can the device be calibrated to different vehicles? I believe that the block 115 is right for our vehicle. Boost generally comes on close to 2k rpm.
