wrong pressure sensor supplied with the electronic readout or dodgy pressure/vacuum sensor? double check the pressure sensor part number is the one to go with a vac/pressure display or check the sensor against an independent vacuum source eg a cigarette socket pump set to vacuum and see if you get a reading. If you get a reading from the sensor then it'd most likely be the readout itself.
- You may not post replies
- You may not edit your posts
Forum Rules
