Originally Posted by
[-Polo GTI-]
you will get used to it. i've noticed that changing from 1st to 2nd, you will only get a noise if you give it a bit, and change gears at around 3000-3500 rpm. from then, changing from 2nd to 3rd, and 3rd to 4th, to get the loudest noise, it is best to give it a bit of throttle and change at around 3000-35000rpm. at the engine heats up, so will the bov, and the springs will loosen = louder sound again.
Personally, my bov is bloody loud, it is not really a good example in the video and i wish i had a better camera, but my gf clearly hears me coming from well down the street and around the corner.
are you sure it has been put on the right way...one of my mates put one on his Ralliart Colt a few months back and had it on the wrong way for about a month before someone said something. when on the wrong way, your car will flutter softly = not good!
have a bitof a drive around doing as i said and see how you go. you should be driving for at least 7-10 mins before you get the most out of it.
sounds good..
wonder if your is as loud as mine
