Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 85
Thread: Blow-Off Valve installed !!
  1. #21
    Mar 2007
    Newcastle, New south wales
    Quote Originally Posted by ryan_GTI View Post
    i'm still on p's
    Copy that
    GTI. Leather.
    tint,Eibach pro-kit,Whiteline adjustable swaybars,Forge s/brace,BMC,Forge T.I.P & D.V, Cupra R, APR. EBC & 3''dump pipe
  2. #22
    Feb 2007
    Brisvegas
    Quote Originally Posted by Kai View Post
    A plumback bov will always be better then atmo.
    You are keeping more air in the system...
    Depends if your car runs a MAP or MAF sensor
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
  3. #23
    Dec 2006
    Gold Coast
    Quote Originally Posted by Spec83 View Post
    why
  4. #24
    Melb, Vic
    any video of it on youtube yet?
  5. #25
    Jan 2008
    why
    Its quite simple really. But first you have to understand what each one means.
    MAP = Manifold Absolute Pressure
    MAF = Mass Air Flow
    A MAP sensor meaure the absolute pressure in the manifold to determine how much fuel to feed the motor. Therefore if the BOV vents to the atmosphere completely the MAP sensor will not detect the air and will not feed any fuel. On the other hand if the BOV is not an atmo then it will detect the air and it will give fuel as requiered.
    The MAF sensor meaures the amount of airflow going into the engine, just after the air filter. Turbo cars that use a MAF sensor have the ECU programmed to feed extra fuel when the throttle is closed and the BOV has been opened to compensate for that air that is being re-fed into the intake from the BOV. Its important to note that the air from the BOV is fed into the intake after the MAF sensor. Therefore the ECU assumes that the air from the BOV is going back into the intake and has no way of knowing that the air has gone to the atmosphere. Because it assumes that the air has gone back into the intake it compensates by giving the engine more fuel so that it does not run lean. The car ends up running too rich for that brief moment and thats why it creates problems.
    Factory turbo cars have the ECU programmed this way because they dont expect you to change the BOV to an atmo unit as this is against pollution laws in most if not all countries.
    Obviously there is more to it than just that, but we wont get too technical to answear a simple question.
  6. #26
    Feb 2007
    Brisvegas
    Spot on explanation Bubu... it is also why you hear a number of wrx / sklines / silvias et al backfiring on gearchanges due to the engine running very rich and not completly burning all of the fuel...
    Can also cause O2 sensor and cat converter issues in the long run
  7. #27
    Dec 2006
    Gold Coast
    wooooooo
    Thankyou for the info
  8. #28
    Jan 2008
    Cremorne, Melbourne
    pics and vid now up guys...see my first post
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  9. #29
    Jan 2008
    I hope it's louder for you than in that video. Especially if you wanted noise.
  10. #30
    Dec 2006
    Gold Coast
    race?
    I should have showed you the noise mine makes today.
