Results 1 to 10 of 15
Thread: Bit of a rumble from the back?
sssstew Bit of a rumble from the back? 07-12-2010, 01:41 PM
blackbetty explain what u mean by... 07-12-2010, 04:00 PM
sssstew a definite droning. Seems to... 07-12-2010, 04:24 PM
Blitzen Jack up the rear end and... 07-12-2010, 07:33 PM
gjuu Not completly rare to have a... 08-12-2010, 06:35 AM
sssstew ah ok thanks gjuu. will... 08-12-2010, 08:34 AM
gjuu Yes and only 24k on the clock... 08-12-2010, 04:24 PM
sssstew jacked it up last night and... 09-12-2010, 11:11 AM
gjuu Mine had no descernable... 09-12-2010, 12:55 PM
sssstew Dealer has said it out of... 23-12-2010, 01:16 PM
sssstew update - had some new Pirelli... 01-01-2011, 08:13 PM
safetyman Bought my '07 Polo GTI on... 12-01-2011, 08:58 PM
Jmac Yep common for the tyres to... 13-01-2011, 04:41 AM
safetyman All sorted! Replacement... 19-01-2011, 04:14 PM
sssstew good to hear, you can start... 20-01-2011, 01:09 PM
    Nov 2010
    Hi All
    Does anyone else have a bit of a rumble from the back end when getting over about 70kph? Not sure if its the exhaust/tyres or if a wheel bearing has gone (which surely is rare on the rear?) but anything over 70k's and its quite a noticable rumble,just wondered if it was just my car or if they are a bit noisy?
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
    Aug 2009
    explain what u mean by rumble?
    is it a droning, a scrubbing, a vibration etc?
    does it happen when you are rolling along at 70 cliicks, coasting, relenting, accelerating?
    06 Polo GTI
    standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
    Nov 2010
    a definite droning. Seems to happen at 70 what ever im doing with the pedal which leads me to think bearing....
    Feb 2008
    Jack up the rear end and rotate the wheel listening for any bearing noise, also try and laterally move the wheel, feeling for excessive free play. Do this on both wheels.
    Dec 2008
    Townsville FNQ
    Not completly rare to have a rear wheel bearing go - my passenger side rear wheel bearing is stuffed - Dealer replacing it tomorrow
    Nov 2010
    ah ok thanks gjuu.
    will take a look like mentioned above. and its going for a service in a week so will get them to look too.
    Dec 2008
    Townsville FNQ
    U20a using Tapatalk
    Nov 2010
    jacked it up last night and checked the movement and it was solid as, so the bearings seem ok... hmmm wonder what this can be...
    Dec 2008
    Townsville FNQ
    Mine had no descernable movement - but when I jacked it up and spun the wheel it rumbled like hell (but only spinning it forwards - backwards it was pretty quiet)
    Just picked it up from the dealer - all fixed
    U20a using Tapatalk
    Nov 2010
    Dealer has said it out of shape rear tyres, so getting them replaced, had cheap Kumos on so going for something decent.
