Results 21 to 30 of 37
Thread: Better Pics of the 35mm H&R's
  1. #21
    Nov 2008
    Wembley, WA
    Quote Originally Posted by mikepologti View Post
    bout to say that 10mm, yeowch that low lol
    so the springs have settled in mozz? not looking higher in the front anymore?
    Yeah my bad typos. 10mm would be pretty funny! gives lowrider a whole new meaning.
    My suspension has levelled off somewhat. Its pretty level now but the rear does sit a fraction lower. I'd say this may be with the bilsteins I have them paired with but never the less the handling is just crazy now. The more I have driven it the less bouncy it's become too. Dead flat in corners and under extreme throttle plus the brakes have developed a whole new meaning and its like they have been upgraded. The bonus is that the overall ride is actually softer. Dead flat & tight but still a soft ride. Quite a bizarre feeling really. Extremely stoked with the overall results.
    Forgot to add that I got the tape out; the front clearance from ground to the black plastic trim under the front fender measures almost exactly 150mm in its lowered form. Interesting , even though the rear sits a fraction lower on the springs, the rear clearance to the black plastic trim under the rear fender is about 175-180mm. But allow the fact the car is not a completely level surface and their does appear to be parts of the under cariage hang lower than where I took these measures.
  2. #22
    Jan 2009
    sunshine coast
    this might be a stupid question but are all of the h and r springs universal? ie you can use them on the back and front universally?, the reason i ask is it possible your susspension mob put them on the wrong end of the car?
  3. #23
    Jan 2008
    Cremorne, Melbourne
    No they're not universal. The fronts are much bigger than the rears. You wouldn't be able to accidentally swap them over, they just wouldn't fit in the spring beds.
    check the picture here, you can see the differece in the fronts and rears.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  4. #24
    Nov 2008
    Wembley, WA
    Quote Originally Posted by [-Polo GTI-] View Post
    Yes and not only that, the rear springs have a mucher higher progressive rate than the fronts. Ie. The more they compress the stiffer they become.
  5. #25
    Jan 2009
    sunshine coast
    holy sh#t , nuf said ., hell evan i can tell the differance between those babys.
  6. #26
    Mar 2009
    England (UK)
    sick lowerage!
  7. #27
    Apr 2008
    I just measured the ground clearance for my car (stock). I got two measurements, one from the lowest point of the plastic cover which was around 110mm and another measurement at the lowest bit of the front suspension which was 130mm. Would they consider the plastic cover or would it be from the actual lowest point on the car (since you can take out the plastic cover if you dont want it)?
  8. #28
    Jan 2008
    Mortdale, NSW
    the polo looks brilliant.
    lowering mine will be the first thing i do to it.
    I've always thought it looks too high up, like its on its tippy toes! lol
  9. #29
    Jan 2009
    Quote Originally Posted by Y2008 View Post
    I stand corrected from the previous page. oh well, they still look like a baby giraffe learning to walk I'm intending to put H&R's in this weekend. I'll try remember to do some before and after measurements.
  10. #30
    Feb 2008
    Perth, WA
    can you please post cost and model type of said springs?
    did you have to change stock shocks also?
