Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Best value brake upgrade
    Aug 2012
    Sydney NSW
    Looking at upgrading the brakes on my Polo Gti.
    My disks are warped and deciding whether to spend a bit
    more to upgrade the brakes at the same time.
    What is the best value brake upgrade?
    Audi TT brakes have been suggested.
    Are there complete kits that include brakes, calipers, brake lines etc?
    If not is there a list of parts would I need to source for the complete upgrade?
    If I only upgrade the front will it affect the overall balance of braking or do we have to adjust the brake bias.
    Thanks!
    Quote Originally Posted by Redliner View Post
    Thanks!
    I have driven a few Polo's with big brakes. The 312mm ones are really good but I think the 288s can work really well too. Just pick a pad with a good reputation and a known quality disc.
    You can get kits from ECS tuning or source it all separately. The caliper carriers can be got off ebay I am sure. I might be wrong but I think you can use the standard calipers. You can on the Golf 4 and A3 which has the 288s standard.
    Then you just need the discs and pads.
    They don't get out of balance but upgrading the back gets you into vented TT/S3 stuff.
    My S3 has standard brakes all round except the pads from GSL Rallysport (QFM) and it performs well on the track and the dust isn't a big issue.
    Oct 2010
    Melbourne, VIC
    Yep, pads and fluid upgrade to start with before changing rotor sizes.
    If there's just an uneven transfer of the pad material to your rotors, you may be able to get them machined instead of needing replacement.
    What sort of use are you intending? I also find the QFM (AR1M in my case) pads to be fade free on track and bite better than stock and on road, they still work fine from cold. I heard they will chew out rotors if you don't use them hard fairly regularly, though.
    Resident grumpy old fart
    May 2011
    Albury, NSW
    I've recently been looking into this and apparently the calipers are different to the Golf IV ones which can be easily upgraded to 312mm. I couldn't find carriers that would, so I just bought Porsche Brembo 4 Pots - Brembo 312mm discs and pads, then adapters and braided Porsche to Vag lines. They're still on their way over from the UK but should be on for GAD (if that still happens).
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Oct 2009
    Canberra ACT
    Ha ha GAD's still on it's just the venue that needs to be finalised
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
    Sep 2006
    Quote Originally Posted by nightphotographer View Post
    Cant wait, going to be a big Polo turnout
    MODS- TOO MANY
    Jan 2009
    blankedy
    QFM pads are well priced, may give you what you want.
    Value is likely TT's from the UK with rotors, pads, etc.
    Aug 2012
    Sydney NSW
    Mainly street driven. I just want to make sure it can stop once I've done all the mods.
    Might have to look at machining discs and running QFM pads for now.
    Nightphotographer, do you mind giving me an idea of how much your Porsche Brembo setup cost.
    Plus where did you get your adapters and braided lines.
    Cheers.
    May 2011
    Albury, NSW
    Bought separately 312mm Brembo grooved and drilled discs were $165 (exc delivery) for two. Caliper adapters, bolts and braided lines are £165 delivered to Aus which works out around $255. Then the calipers - well that varies, I got mine off a 2003 996 which was crashed at 50k - they're in perfect condition, and that's a really low KM for the UK so I paid a bit more. But generally calipers are around the $500 mark. And then you have to get everything over here, which is easy for me because my dad picks everything up and forwards it on to me...or like with my Bluemotion Front Lip - it get's brought over by my mum haha
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Aug 2012
    Sydney NSW
    Nice setup. What are you running on the back?
