Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Best value brake upgrade
  1. #41
    They weren't officially imported, as far as I know only one or two are here. Maybe I should put together my own build/intro thread in the polo forum.
  2. #42
    May 2012
    Perth, WA
    I've seen somewhere people using Bora spindles for their barke upgrade
    So basically a mk4 one should probably fit
    Try partsbase.org for part numbers
    06 Polo TDi
  3. #43
    Oct 2010
    Melbourne, VIC
    I think the reason people here find the Golf/Bora spindles don't work is that they try to use them with the Polo GTi calipers - you need to use the calipers that match the spindles, so a MkIV Golf GTi brake conversion should work.
    That said, I'm tracking with the little 256mm (10") front rotors and can get the ABS operating with semi-slicks on so I don't find the small brakes lacking in power (they do get super hot and will fade the fluid if going 100% but I ran for over an hour at 95% without probs).
    Resident grumpy old fart
  4. #44
    Ok, this is the type of info I needed. I took a quick look online and the 256mm rotors were going to cost me $200 before I even get into the cost of the pads. 288mm Golf and Bora/Jetta spindles are very easy to find here. Plus the replacement rotors are about $30 each.
    The downside is that I would need to install larger wheels and tires, but the tire size is the same that I would run on the Corrado so I can just use my spare 16" wheels.
    The only other option that I'm not a big fan of is drilling the 256mm 4x100 rotors to 5x100.
    Thanks for the input
  5. #45
    Erskineville, NSW
    Rather than buy your parts locally, just do what many of us Aussies do & buy them from an overseas supplier - maybe the UK or even Brakes Direct in Australia.
    There must be plenty of ebay suppliers in the UK
    Quality pads, aftermarket rotors & decent brake fluid & your done without having to mod the daylights out of things.
  6. #46
    Modding the daylights out of things is a disease that I suffer from:
