Originally Posted by
seangti
Last I spoke with GSL, the A1RM's are a special order and require your brake backing plates and they don't recommend them for street.
I use QFM A1RM's and they bite fine for street use but if you don't use them hard, they will get noisy and wear your rotors - they need decent heat to make the pad material transfer properly to the rotors to prevent this. But they work very well if you do track your car.
Resident grumpy old fart
