Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: Best value brake upgrade
  1. #31
    nsw
    My rotors have a decent lip on them and will probably need replacing when I do the pads next. I'm happy to stay with stock 288mm rotors and I'm glad that comments from a few of the guys on here back them up.
    Eddy when you say that the standard setup works really well , by that do you mean the factory VW rotors in particular, or that its the stock 288mm diameter that is fine?
    One of the things that was suggested to me by a local VAG specialist shop was that the metallurgy of the VAG product is superior to a lot of aftermarket stuff and that a good way to improve stock rotors is to machine slots into them. Anyone opinions on that?
    I always thought that the VW rotors were designed to wear with the pads compared to say Japanese OEM setups. Is it Ok to use aftermarket pads on stock rotors and not introduce really bad rotor wear rates?
  2. #32
    Erskineville, NSW
    I think VAG rotors are prettycrap and lip too quickly.
    Get something like DBA T2 slotted rotors ($165 ea), some decent brake fluid like ATE SL6 ($13) or Pentosin Dot4 LV ($26/L) or even the OEM B000750 class 6 fluid and QFM A1RM ($120) or Remsas ($105). If you don't want to restrict yourself to a class 6 brake fluid then DOT5.1 is the closest you'll get to the viscosity requirements.
    Or go all ATE with SL6 Fluid, ATE Ceramic pads & ATE rotors.
    There's a heap of choices out there that are better than OEM VW.
  3. #33
    Jan 2009
    Quote Originally Posted by sambb View Post
    I had a set of rear standard RDA rotors slotted, hard to say if it made any difference. I'd steer clear of running RDA rotors on front or rear, I started getting vibrations after 15-20,000 km. Had them machined and shortly after the vibration came back. I now run DBA T2 all round on the silver car. I had tracked the car a lot with the factory pads, rotors and fluid as the car was near new, and was fine. As the car got quicker with suspension and tune, the temps required better pads and fluid. Re running different pads on the standard rotors, its ok. How many kms are on the rotors? They may need a machine, but a more aggressive/aftermarket pad will clean the rotor anyway. If the rotor is in good condition, I'd do the pads and learn of bedding them in.
    I've ran a few sets of Remsa pads and am one of only a few to have cooked them on the track. For hard street or considerate track work they are fine, but run semi slicks, no ducting and drive em hard you will find their limit. Last I spoke with GSL, the A1RM's are a special order and require your brake backing plates and they don't recommend them for street. Im now running a bendix pad on the daily car and that performed marginally better than the remsa did at a timeattack event.
    I've also only ever ran a dot 4 fluid. I'm running a dot 4, penrite racing or something. By all accounts, that should be more than adequate.
    Daily: 2010 VW Jetta Highline
  4. #34
    Erskineville, NSW
    The trouble with machining a rotor is that they are basically heat sinks & maching reduces the mass, which reduces the ability of the rotor to shed heat.
    VW specs since 2006 call for a low viscosity fluid. Dot 4 is about double the viscosity. Dot5.1 comes close but us still about 10-20% thicker than class 6 fluid.
  5. #35
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I was happy with the factory rotors & the 288mm diameter is fine, even for very spirited driving.
    Though I say I was happy, it was not till after tuning up a few things.
    If ya going to replace rotors, look into curved cooling vanes instead of the standard straight vanes, but only if ya want more cooling. I don't know what's available @ present in 288mm.
    Project Polo - 1min10 around Wakefield
    Hooroo.
  6. #36
    Aug 2012
    Sydney NSW
  7. #37
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by seangti View Post
    I use QFM A1RM's and they bite fine for street use but if you don't use them hard, they will get noisy and wear your rotors - they need decent heat to make the pad material transfer properly to the rotors to prevent this. But they work very well if you do track your car.
    Resident grumpy old fart
  8. #38
    nsw
    Thanks for all the advice. Seems that for my needs the stock front rotors will be fine and i'll look into the different street pads. Anyone know what minimum thickness is?
  9. #39
    Hello, so is there an alternative to using a 9N GTI spindle on the non-GTI cars? I have a 16V and it looks like I'm stuck with tiny brake rotors which aren't easily found in the USA. Has anybody tried comparing jetta/golf spindles? I think the ball joints are the same.
  10. #40
    Jan 2009
    Quote Originally Posted by G60ING View Post
    I'm surprised to see you have a polo in the USA, didn't realise you received them over there. Would have put money on it. Sorry can't really help with your question. I don't believe the golf spindles fit, though others are more mechanically astute than myself.
