Hoyhoy.
Yeah, me did upsize but only in the rotor department the Mk-1 TT have the same size caliper pistons as the Pog.
The standard brake set up with a bit of tuning (extra cooling, slotting, pads & fluid) is more than adequate for any spirited driving & even reasonably quick track runs.
Its just when you're really humping it that heat becomes a problem.
E.G. 1'13's @ Waky was O.K. but 1'10's aint.
Hooroo.
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
what are your thoughts on these disks?:
Front Brembo Max Brake Discs VW POLO 1.8 GTI 01>10 | eBay
Plus any idea what these pads are like?
Front BREMBO Brake Disc Pads VW POLO 1.8 GTI 05 ON Sport Track Road HP | eBay
Honestly, contact Greg at GSL Rally Sports. It's worth buying from him for the service and real world advice that he will supply along with the parts at a good rate.
I'm as cheap (maybe more so) as the next guy but dealing with experts like him save you money in the longer term.
Resident grumpy old fart
Watto, there's nothing wrong with the servo mate. You can stick to standard 288mm and some better pads. Replace the fluid for some with higher temp handling.
This is plenty good enough for track work.
If you have more money then replace the calipers and brackets with S3/TT/4motion ones and get 312mm discs and pads.
I have this on my Polo and the brakes are pretty good.
Hoyhoy.
Upgrading for street purpose is not necessary @ all, the standard set up works real well.
Good pads & fluid can make a big difference..
I'm still running the standard master cylinder with the upgraded rotors front & rear because the wheel brake cylinders are of the original size.
Hooroo.
