Results 1 to 10 of 11
Thread: bench flash tune
    bench flash tune
    Hey guys,
    Went to get my polo flashed on the weekend, but the ecu came back with some errors. (I have no idea what these errors were) They said that they will have to take the ecu out to flash it but there is a chance this could fry the ecu and a new ecu could cost up to 2k to replace!
    So I said hold up and didn't proceed.
    Has anyone else experienced this? Will I have to change my ecu if i want it flashed?
    Ive read that if i change the ecu i will have to change all my keys etc.
    new ecu + tune seems like an expensive exercise.
    it was to be a Revo tune.
    Did Revo elaborate on what the errors were? Has your ECU had any trial flashes loaded to it?
    You can get an ECU for less than 2K. I bought one from ebay UK for 40 quid. I got the immobiliser defeated by Custom-Code, so that I could use it as a loaner. 06A906032TL should be the number.
    You could do the same if it goes wrong? I'd be prepared to lend you mine to keep you on the road.
    You need to know exactly what the errors are - If it's a CAN / K Line issue then it probably can't be flashed in the car (even a new ECU). Chances of hurting it or killing it on the bench would be pretty much nil as long as the operator knows what they are doing.
    Try another tuner if you can't go anywhere with the Revo.
    Dec 2010
    jhb, south africa
    I had a k line issue, just cut the k line cord off and it will work
    gavin,
    had no trials just jumped on in.
    will call tomorrow and see what the errors were.
    Any other way to see what the problem is if i don't get answers?
    guy/dood - Being a novice in this dept what is a k line / can - I'm assuming its the connection to the cars ecu?
    Dec 2010
    jhb, south africa
    Quote Originally Posted by waxgti View Post
    gavin,
    If they cannot connect to the ECU in the car, which would be most unusual, it's going to be the wiring as Guy has pointed out.
    Bench flashing is safe as houses IMO.
    If you don't get the answers or a decent explanation of why they think that the ECU could get damaged during the process? Go somewhere else.
    My offer of the ECU still stands
    Adelaide hills, SA
    gavin,
    Are you the first owner of the car?
    These cars have both K & Can communication wires, the programming is carried out by the K-Line, and if that's "dirty" then you will have trouble programming (even though you can still do diagnostics via CAN).
    We see it occasionally & sometimes it's made worse if aftermarket equipment is installed (like adapter plugs for Bluetooth kits, radio's etc) but sometimes its the wiring in the vehicle that has deteriorated over time.
    im second owner car has 85k.
    Just spoke to them, pretty much said that when they were trying to flash they were losing communication, therefore continued flashing then lost communication would result to a fried ecu.. I asked if it could be wiring, they said could be a number of things including other computers on board??? and there is no way to tell exactly what the problem could be - no test to determine what it is. They also said they would strongly advise against flashing the ecu. After I asked if they could look around for a replacement ecu, i asked again today and they said they havnt been able to find one, which sounded more like they hadnt even checked.
    I think ill go to another revo dealer and see what they say, as you can imagine Im a bit disappointed. failing this ill check out other tunes, which one is best? (haha j/k)
    Gavin, if my woes continue and every place says i cannot do it, then maybe ill give it a shot and may take you up on that ecu loan.
    but i think ill only go there as a last resort.
