If they are cheap and in good condition, grab them.
You can always sell them for a profit if nothing else...
Hi All,
Haven't had much intrest in the car for sale however, I have been presented with a to pick some BBS RS wheels up cheap...
Do you think that a 16x8 +20 wheel would fit on a Polo?? The offset calculator on 1010tires indicates that there will be 1mm less internal clearence but a large-ish 37mm extra outer clearence. My measurements would indicate that +37mm on the outside would be close, but not impossible to fit with a bit of tyre stretch...
Has anyone else fitted this combination to a Polo before or know of someone who has?? Will be running 205/45 tyres![]()
you can run at +20 fine, I was running +19 in the back on H&Rs .
might have to bend the screw tab in the front arches back though if you run 205s and are lowered more than 35mm if you run 195s you'll be fine though.
I'm guessing +20 is after adptors or at 5x100?
you might be able to shave 5mm-10mm of the backing plates to give you a bigger offset too
205 on an 8 is not much stretch TBH, especially a 205/45. 195 would be better and scrub less depending on your sus setup
