Results 1 to 6 of 6
Thread: BBS Wheel Question...
    Feb 2007
    Brisvegas
    Hi All,
    Haven't had much intrest in the car for sale however, I have been presented with a to pick some BBS RS wheels up cheap...
    Do you think that a 16x8 +20 wheel would fit on a Polo?? The offset calculator on 1010tires indicates that there will be 1mm less internal clearence but a large-ish 37mm extra outer clearence. My measurements would indicate that +37mm on the outside would be close, but not impossible to fit with a bit of tyre stretch...
    Has anyone else fitted this combination to a Polo before or know of someone who has?? Will be running 205/45 tyres
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
    Jan 2009
    blankedy
    If they are cheap and in good condition, grab them.
    You can always sell them for a profit if nothing else...
    S.E Melbourne
    you can run at +20 fine, I was running +19 in the back on H&Rs .
    might have to bend the screw tab in the front arches back though if you run 205s and are lowered more than 35mm if you run 195s you'll be fine though.
    I'm guessing +20 is after adptors or at 5x100?
    you might be able to shave 5mm-10mm of the backing plates to give you a bigger offset too
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
    Feb 2007
    Brisvegas
    Quote Originally Posted by Whubbsie View Post
    Nah no adaptors, the wheels are 5x114.3 with an ET+20, so will have to get them re-drilled... Might go and check them out tomorrow and see if they will fit...
    Just trying to imagine what a 205 will look like stretched over an 8" rim
    205 on an 8 is not much stretch TBH, especially a 205/45. 195 would be better and scrub less depending on your sus setup
    S.E Melbourne
    Quote Originally Posted by Spec83 View Post
    205/40 stretch on a 8inch not much stretch
    Quote Originally Posted by Lorenz View Post
    like Lornez said you'll have to go to 195s if you lower the car.
    you sure your calculations are right? at+19 my rears only poked 13mm
