Results 1 to 10 of 14
Thread: Battery Life
    May 2007
    Burleigh Heads, Qld
    Battery Life
    I've had my Pog since Aug 07 so nearly 3 years old. Still using the original battery though it sounds like it could be just starting to slow down. I'm wondering what sort of battery life others have had?
    Adelaide hills, SA
    In my T5 the battery died after 2 years. However Varta batteries improved in last years. How long your battery lasts depends from how many starts you do per day and how long your daily trips are. I do a lot of short trips and and first 2 years I never charged up battery from the battery charger, it extends the life of the battery if you use battery in such conditions I do. After the dealer replaced the first battery for free I bought CTEK battery charger and I charge the battery once a week, now after 3 years second battery cranks strong even on very cold mornings.
    Generally a good battery should last 4-5 years and I saw some batteries to last 8-10 years, they were GS, Panasonic and Yuassa batteries in Jap cars.
    Jan 2009
    blankedy
    I'm still using the orignal battery (I assume) in an '06 Polo. No issues yet...
    Jul 2005
    as stated above it really depends upon what you do with it. In our cabrio i replaced the battery after 5 years from new. nothing wrong with it afaik but it had a hard life for the last 12 months as the car did not get regular long drives and i had let it go flat a few times and jump started it to get it going. Flattening and recharging is not good for a battery. They are best kept topped up if you can. lots of starts for short driving distances are also not good for them.
    After we replaced the battery the new one died within 6 months and had it replaced under warranty with no faults in the new battery so far. I now have a trickle charger that is connected to the battery all the time to keep it topped up.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Mar 2007
    Gold Coast
    My original battery died yesterday (early 06 build). It had been cranking slowly for a month or so and the cooler weather got the better of it.
    Jul 2007
    Auckland, NZ
    Still on original battery from Feb 06 registered - probably Dec 05 assembled car. Starts strong first time all the time, has ipod getting charged all the time in situ.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Aug 2007
    Anything over 3 yrs is on borrowed time in my opinion. Best of all which makes it hard unless it showing obvious signs it can test good and die a couple of days later. Temperature change is a biggie. The cold in the Uk likked them and the heat here kills them. They can short at the drop of a hat, epsecially after the shelf life. Teasing it by leaving a light on or a radio on can be the catalyst. You would be amazed when i was back in dealerland how many batterys we changed in the 1st year of warranty. This goes for Porsche,Audi and vw where ive worked, no different. Batteries piled to the roof is common place
    Jmac
    Alba European
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    I really think it depends on what motor you have and the brand of battery.
    Diesel is going to have a larger battery and should last longer.
    As mentioned above try and buy a Yuassa or any made in Australia.
    NRMA = fully imported crap (lasted 18 months in parents car)
    My old isuzu ute 20 years old next year is now on its 3rd battery, replaced again about 12 months ago .
    First two lasted about 9 years each,
    First was a Yuassa made in Japan , secound yuassa made in Australia, third century made in Australia
    from the factory which made yuassa so I'm told to believe, could not get a yuassa this time.
    You could try Inox a battery conditioner to extend the life of battery.
    Adelaide hills, SA
    Quote Originally Posted by neil View Post
    Diesel engine also drain/load battery with much bigger current than petrol, they also crank longer in cold and use glow plugs that put a lot of load on the battery before you even crank the engine, so there is not advantage of bigger battery.
    How long your battery will last depends from how pure are metals and other materials they made the battery from, and from other elements.
    Original battery died last week late o7 model, called vw assist and they changed it on warranty
