Results 1 to 6 of 6
Thread: Battery downsizing / replacement
    Jan 2009
    blankedy
    My 2006 GTI is due for a new battery, I have no symptoms of it dying yet, but I would like to replace it before it stops working as it happens quite suddenly to some.
    Thinking of going down to a compact battery, saving some weight, making some room and getting rid of the excess garbage around the area. May assist me to move to a POD setup (maybe).
    I've seen a little info on it, but can't find much. I'll need to make up a battery cage / holder, which should not be too difficult. My main concern is relocating the existing connections and any rewiring if the stock cable is not long enough.
    Can anyone help me with what they've done or does anyone want to work with me on a little DIY project?
    Oct 2010
    Melbourne, VIC
    PM vwthunder for some pics and advice on this - he spent a lot of time and effort on this and his battery setup is very nice indeed.
    Sep 2006
    Quote Originally Posted by kaanage View Post
    Oh thanks
    Hang on i willl try to find some pics
    I made a flat tray, out of 6mm aluminium plate
    You can buy the earth cable already done, which i did
    I had to extend the positive cable, just used a car audio joiner from Jaycar
    You will be amazed how much room is in there when you remove the airbox and battery
    Sep 2006
    Sorry dont have any really good pics
    You can actually see the join under the heat shrink on the positive wire
    Jan 2008
    Sunshine Coast
    I believe Polar is still running his tiny Deka motorcycle battery in his MKV GT TSI, but mine started to get weak after a year of turning over the high compression diesel and running my big sound system, I have a mid sized Oddessy and it's been awesome, plus a fraction of the stock size.
    Feb 2007
    Brisvegas
    Mine died suddenly the other week and I replaced it with a golf spec item which had more CCA's.... The battery cage is a complete pain in the ass to get out, I broke the rear mount off so I won't have the same problems next time
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
