Originally Posted by
Bullet Fast
Just be aware, narrow tracked vehicles, mac strut front ends and high-ish COGs are going to need a bit of camber to turn best at limit of adhesion which causes some traction issues under hard braking and acceleration in FWD cars.
Yes, I have certainly found that I have less traction out of turns on my road tyres since fitting the camber plates, although I think the stiffer front ARB I had fitted at the same time also has contributed to this.
Resident grumpy old fart
