Results 31 to 39 of 39
Thread: Bang for buck fabrication jobs...
  1. #31
    May 2011
    Albury, NSW
    Quote Originally Posted by waxgti View Post
    MILD STEEL would be BOSSSSS, someone cut theirs out
    If my mk1 was roadworthy mine would be in the mail to Bullet Fast - come on guys, surely someone has got this lying around?
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  2. #32
    Sep 2006
    I dont really see the point in Fabbing up downpipes, any exhaust place can do it, not too hard
    Rather see something a bit more special like control arms or camber plates, things like that. Just do what we did on my car, get a MK4 downpipe cut it a few times and weld it back together
    Oh and it has held together better than the APR one did
    MODS- TOO MANY
  3. #33
    Quote Originally Posted by vwthunder View Post
    I agree with vwthunder re downpipes, any exhaust place can do it, not too hard.
    The Strut top Mounts and bearings go early on these Polos and Qld roads do not help!!! Cheers Al
  4. #34
    May 2011
    Albury, NSW
    You forget I live in Albury - if it's not Holden or Ford, they point to the door lol. I've had people plain refuse to do work purely because it's a european car...they know nothing about them.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  5. #35
    Sep 2006
    Quote Originally Posted by nightphotographer View Post
    Move to Melbourne then lol
    MODS- TOO MANY
  6. #36
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Bullet Fast View Post
    Just be aware, narrow tracked vehicles, mac strut front ends and high-ish COGs are going to need a bit of camber to turn best at limit of adhesion which causes some traction issues under hard braking and acceleration in FWD cars.
    Yes, I have certainly found that I have less traction out of turns on my road tyres since fitting the camber plates, although I think the stiffer front ARB I had fitted at the same time also has contributed to this.
    Resident grumpy old fart
  7. #37
    Nov 2012
    Well this should be pretty obvious to anyone looking -
    I took the rear end apart measured up a heap of things and modelled it back into solidworks with enough details to run maths off a static loaded model. This isn't the best suite of software for determining suspension geo, but is the best to design parts into it. I'm really not keen of measuring the entire chassis to pull exact roll centres, COGs etc... If someone else wants to do this I'll model the whole car!
    Anyway, because wheel alignments come in linear measurements at the rear instead of angular... I had to model everything from the axle out to determine where I could alter things. I have another wheel alignment on Thursday, so once I have a base line I'll feed the stock, albeit lowered figures into Solidworks, and see how much I can gain, and where.
    As a curiosity, my lower two stub axle bolts sit perfectly parallel to the ground at 662mm (arch to ground) ride height... odd no?
    Pretty pictures.
    Hub off
    Horizontal stub axle bolts?
    Masked up - roughly
    Touch of paint and voila! Normally I'd use bearing blue for this but I couldn't find any. Just wiped it off. wet.
    Reverse engineered on paper looking for design intent, angles, concentricities etc - I have to assume the print wasn't perfect, so I'll make a couple of variations initially based on geometric assumptions and adjust from there if it doesn't fit quite right.
    Measuring up a couple of bits.
    Axle block model.
    Wheel mock up on a hub on an alignment jig showing a nominal or stock camber through an evaluation tool. I'll feed my numbers into this after Thursday... I did the wheel cause it made me smile - otherwise the only important dimensions are outter dia and offset...
  8. #38
    Eltham, Victoria
    We're going to get along just fine, my camber-inducing wizard friend.
  9. #39
    May 2011
    Albury, NSW
    Quote Originally Posted by Bflat View Post
    +1
    I have no idea what's happening here but I LIKE IT!
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
