PCD 5x100 57.1 wheels -Wheelfitment.eu | PCD, Offset, Center Bore, mounting and tire size data
there's all your options rgvlee![]()
I've come across a set of tt rims
17 in, 5x100, 32 offset
Pretty sure they'll fit, can anyone confirm?
What's the offset range that suits the 9n3? 32-40 something?
08 9n3 Polo GTI
Mods: heaps
put your before and after values into this site and it will tell you alot.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Offset means nothing without first knowing the width - Got any info there? 8", ET32 would *just* fit with a 205/40
Cheap, Fast, Reliable. Choose two.
Yes, they fit. I have a set that I use as track rims (daily's as of today). They fit fine, no scrubbing on the outer or inner guards.
Just bear in mind they are quite a heavy rim so you may notice the difference in weight. I run 215 width tyre.
Daily: 2010 VW Jetta Highline
** All information I provide is probably incorrect until validated by someone else **![]()
they are 7.5s, been done plenty of times on polos
Yeah they are probably 7.5 wide. I haven't been able to see them or get the seller to confirm, he doesn't seem to know much about what he's got.
It's the offset that I'm interested in and these ones are 32. From what I can tell there are a number of tt rims with differing offsets.
Sean what offset are yours?
I'm not worried about the weight I just want another set of daily rims so I can put some decent track tyres on my other set.
Yeah mine are also the 32 offset. Mine are quite flogged as they've been a track rim for years and never shown any love. It was only yesterday when swapping tyres that I'd realized there was quite a dent on the inside lip of the one of the rims... wasn't meI'm now going to get them refurbished to run as daily's as I put new semi's on the enkei's.
I assume the wheels are from an early gen TT, they are the ones you need to my knowledge, I don't think the later wheels fit though I couldn't tell you whether it's offset or stud pattern.
These are from an 02
08 9n3 Polo GTI
Mods: heaps
