Results 1 to 10 of 16
Thread: Audi S3 brake upgared (Caliper painting)
    Mar 2006
    South Hobart Tasmania
    Hey all finaly spent some time this arvo cleaning the Audi S3 brakes i have. Spent about 2 hours with a wire brush and sand paper trying to get rid of all the dust that has been weathered into the calipers. Think i am almost there.
    The Rotors are 312mm i think the standered ones are 288mm.
    The next step is to rub down with a solvent to remove any left over grease and oil.
    Ill try to paint them as soon as i get a good day.
    I am told that they should fit under the 16" wheels.
    Standered Brakes.
    TT Brakes(Thanks to Guy Harding pics are from his project polo.)
    Same size as S3 i balive.
    Will be taking the calpiers after painting to a Brake place to have them all checked out seals ect.
    The plan then is to go for EBC green stuff pads, good fluid, Braided lines and then maybe ATE Power Rotors should have the pogo stopping in no time at all.
    Will post agin as soon as they are painted and agian once they are on the car.
    Part numbers are:
    Calipers: 1x 8N0 615 423 C (caliper)
    1x 8N0 615 424 C (caliper)
    Caliper Carriers 312mm Audi Caliper Carrier 8N0 615 425 2 EA
    Rotors 312mm Audi Brake Disc 8L0 615 301 2EA
    Oct 2006
    sydney
    nice work look into some silver wurth spary once rotors are dirt free will stop squeeks and rotors will look like new just spray on rotor surface will run off onto pad at later date
    nice work scoring some s3 calipers they are the same as the r32 but without the blue caliper paint,
    like your wheels i scored a set for 1000 with rubber brand new.
    falken azenis range now have 16s street sick would be worth looking into
    Mar 2006
    The R32 had 334mm (13.1") Vented Two Piece Front Rotors
    Two Piston Calipers (with seperate Caliper Carrier
    The S3 has a singel Piston Caliper same as the Golf MK4 GTI and i think even the MK5 may be using the same Caliper, i think the front calipers on the polo are the MK5 Golfs Rear Calipers.
    Oct 2006
    sydney
    the passat v6 calipers are single piston and the rotors are floating they are similar do you think they could do it also
    Oct 2006
    sydney
    the s3 calipers are very similar to the mk5 but with out the springs on the front they looks similar to the original polo if u look through wheel on the pic of your original caliper you can see
    Mar 2006
    Not sure i would have to have a Golf mk5 to have a look lol ill see one day.
    Oct 2006
    sydney
    anyway it looks nice so what is planned for it ?
    it is goin to be used for race aplication or street
    Does the Polo not have same calipers as the S3? I know the calipers on my A3 are the same, I just got the 312 brackets and some discs.
    Can't vouch for how good the Green Stuff pads I have might be, as you aren't allowed to go fast enough to need good brakes in Australia ;0).... They work ok coming down from 70!
    I know the 312s on my Leon Cupra took a hammering following the custom-code flash. I had to cross the Peak district from Chesterfield back to Warrington. Some good driving roads and not too many Police.
    Mar 2006
    Mainly street but hill climbs, track days plan is to one day, once i have enough skills is to do the duton rally. May be even Targa Tas one day just need more experience and alot of money.
    Ummm from what i can see the polos front calpiers are very diferent from the S3s.
    Nov 2005
    awesome.......don't you just love bolt-up mods.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
Similar Threads
  1. Mk1 Commodore Caliper, 278mm Magna rotor conversion
    By golfnutracing in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 06-06-2011, 04:23 PM
  2. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  3. VR6 brake caliper guide pins - hex Size???
    By gman in forum Mk3 Golf & Vento
    Last Post: 17-02-2007, 04:11 PM
