i emailed Tempe last night ill call them around midday i guess.
dont think you would have to worry with a polo.
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
man 20" on a polo that would be funny.. almost as funny as this 200SX with 22" Chromes which goes on the cruses.
Just a update on price, its $175 for 17" 5 x 100 from tempe.
Just a issue tho the guy from tempe said it need a 45 offset or it will hang over the guard ? i am abit confused.
you need to be careful in calculating the offsets on wheels. with the info off your orig wheels... width and offset you can calculate how much movement there is with the new wheel size and offset.
ie just coz your orig wheels are +35 offset does not mean any wheel with an offset of +35 will fit... width of wheel has to be taken into account.
google a wheel offset calculator and it will tell you how much the location of the wheel changes. Measure up against your car. If you have the space, ou are fine. Although if there is a small margin for error, tyres will come into it.
Interesting. When I got my Jestalts from Ozzy here in Newy, they drilled the right PCD into them, and got the right width/offset for my car. Why can't tempe esentially do "custom" fittings for your polo?
i dont know, i had a feeling the guy was not being very helpful because the wheel were not going to be in stock for 8 weeks... answering questions with 1 word answers etc
When i said is that 35 offset? he said what year is your car ... nope 45
Here you go.
Standard GTI (i think its a GTI) would be what, 16x6.5 with the ET of 35.
Im thinking your new wheels would be 17x7.5 at ET45. Diameter isn't important here.
Plug into this
http://www.1010tires.com/WheelOffsetCalculator.asp
Inner Clearance: 23mm LESS (the inside of the wheel to the strut housing)
Outer Position: Extend an Extra 3mm (position of the outside edge of the wheel)
Hope that helps. Do it yourself. My specs on your reps may be wrong....
