Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 107
Thread: APR vs GIAC vs Revo - Need opinion
  1. #21
    Jun 2008
    Either chip you will be happy and either chip will give u more power then you can control, so dun worry and chip according to ur budget!
  2. #22
    Oct 2006
    Quote Originally Posted by hkogti View Post
    Why do you say that?
  3. #23
    Jan 2008
    Quote Originally Posted by firdausasri View Post
    Seems I've to pop to the shop again for free trial (if it's possible in here). What I need is more towards smooth power delivery and and extended powerband rather than outright peak power. Those of you had chipped, posssible to share dyno chart? That would be great to see if there's anything being sacrificed at the low-end revs.
    With chipping and sprint booster, it'll be sleeper shopping trolley at night hahaha
    Lol, don't get a sprint booster... learn to drive properly instead. You will need to learn to use less accelerator rather than have it at full throttle half way down.
  4. #24
    Jun 2007
    Flaps - what's with the Golfs pulling away and overtaking you in that vid ..with all the go you have now, how come you didn't give them hell?
  5. #25
    Feb 2008
    Before I went with a particular chip I trialled all 3 major brands (APR, GIAC & REVO).
    I was looking for smooth power delivery but price also played a part. The Revo tune felt stronger at high RPM but wasn't as smooth or as torquey below 4000rpm as APR and GIAC. APR and GIAC felt very similar with both been smoother at lower RPM (2K-4Krpm).
    The prices I was quoted at the time were:
    APR $1850 for two programs (this has now dropped to $1590)
    REVO $1499 + $299 for the switch with 2 programs ($50 for each additional program)
    GIAC $1200 + $249 for the switch with 2 programs ($50) for each additional program)
    So I went with GIAC as I was on a budget and they all felt just as powerful as each other.
    Also GIAC was the last tune that I trialled and they were the only ones who erased previous flashes from the ECU before installing there software. This means that if a dealer plugs in there computer they will only see that the car has been flashed once.
    Please don't take this as me being biased towards GIAC as the tunes were all very similar so I'm just trying to be as informative as I can
  6. #26
    Jan 2008
    Western Sydney
    are each of the big 3 (Revo/GIAC/APR) undetectable to a dealer once switched to the stock tune?
    i know revo advertise this feature on their website
  7. #27
    Feb 2008
    Quote Originally Posted by Grant View Post
    They are undetectable apart from the dealer been able to see how many times the car has been tuned with APR and REVO.
    I got the trial for GIAC last out of the 3 and by then once the guy at GIAC had plugged his computer in it was saying that my car had been flashed 4 times with the 2 probably been at the dealer and 1 APR trial and 1 REVO trial. When the GIAC trial had been done the computer was only showing that my car had been tuned/flashed once as they delete the previous information from the ECU.
    With APR and REVO if you were trying to get warranty work done and the dealer saw through VAGCOM that your car had been flashed several times they may then start to question if the car had had work done to it.....
  8. #28
    Mar 2007
    Quote Originally Posted by callen View Post
    This does not happen. I can speak for APR when I say they remove all code signatures etc. when the flash is purchased ... I'm pretty sure REVO would be the same.
    Dave
  9. #29
    Feb 2008
    Quote Originally Posted by DaveMack View Post
    Dave
    Not sure about when you purchase the tune but they certainly don't when they load the trial.
  10. #30
    Jan 2008
    callen: they don't show in VAGCOM at all.
    The only time they show is if the dealer tries to reflash with their stock map it will say 'are you sure you want to go over the current map'.
