yes... I have tried to use the search function, but could not find a definitive answer...
my GTI is running APR Stage 1 tune, it is till running on stock spark plugs with 53,000km on the clock, so I figured it is about time to change the plugs to keep it healthy...
but there is a whole lump of crap (SAI?) on top of the rocker cover, do I have to disassemble everything before I get get to the plugs? Or just undo a few bolts that are holding them to the rocker cover, and then they can just be pushed to the side?
and what sort of plugs should I choose? would you guys recommend a specific model/brand? I read somewhere for tuned GTIs the gap should be narrower than stock? do I have to go for the ultra expensive iridium plugs or just a set of normal plugs?
Thanks!
thanks! will try tomorrow...
NGK BKR6E sounds familiar...
the website says PFR6Q, only Autobahn stocks it in Canberra, and they want $25 for EACH PLUG!!!!
is it just me or it seems extremely expensive?!!?!
there is a Bosch alternative that Repco stocks, for about 8 bux each, will there be any major difference if I go with the cheaper Bosch?
ebay.....
Try Bosch FR5DTC. Im using them and they're one step colder and I'm very happy with them..they're 3 prong plugs so can't do anything with gaps. Guys on audizine ran as high as 37psi without issues.
Could get them through Bosch AU's online store for about 5-6bucks each.
============================> http://www.facebook.com/EuroCarModsAus <============================
